Second stupid question of the day... re starter sprocket...
rzgkane
Post by rzgkane » Sat Feb 25, 2012 12:28 am
When re-assembling, how does the rotor and its attached starter clutch assembly couple up to the crankshaft's starter gear/sprocket? Are the dogs/rollers of the starter clutch retracted enough for the rotor to simply slide onto the protrusion of the sprocket? Or do I need to retain them in some way?
Post by davomoto » Sat Feb 25, 2012 11:12 am
The rollers will stay in place. Line up the keyway, and wiggle the rotor on.
Davo
rzgkane
Post by rzgkane » Sat Feb 25, 2012 2:15 pm
davomoto wrote:The rollers will stay in place. Line up the keyway, and wiggle the rotor on.
Davo
Thank you. I'm a crankshaft starter sprocket seal away from putting this bad boy back together. It was the real leaker. I shouldn't have even messed with the crank seal.
