CHECK OUT THIS BIKE FOR CORRECTNESS "CL77 HONDA"
Post by LOUD MOUSE » Mon Dec 12, 2011 10:53 am
Tis been a while since I've offered a challenge to the members who know these bikes.
This CL77 has visible defects as parts are concerned.
Use the description as ya look it over.
Ya can consider the asking price also.
Check it out and tell us what ya see.........lm
eBay 180774519189
Snakeoil
Post by Snakeoil » Mon Dec 12, 2011 2:51 pm
I'll give this challenge a shot. Here's what I think is wrong.
Fenders should be chrome
Brake levers should be non-rib type with black rubber caps on the ends.
Starter coverplate should be plated, not painted black
Exhaust has correct heat shields, but muffler has been cut off.
Tank should not be clear coated
Plug wires are no original, nor are the plug caps. Wires should also be run thru the guides, which are there.
Points wire is in woven metal fabric tube. Should be in white, high temp glass fabric tubing.
Handlebar clamp and top tree are polished and they should be painted.
Hubs and brake plates should be satin/brushed finish with clear coat, and not high polish.
Valve caps should be satin, not polished.
Kick start look either bent or wrong.
Butt-ugly weld repair on front fender brace.
Repop tank badges.
How'd I do??
regards,
Rob
Who used to read Where's Waldo while sitting on the pot.
FAST FRED
One More
Post by FAST FRED » Mon Dec 12, 2011 3:31 pm
Wrong lever perches.
Fast Fred
65 CL77
66 CL77
76 CB550FKR
76 CT90
Hotshoe
Post by Hotshoe » Mon Dec 12, 2011 3:42 pm
+ front fork boot clamps missing, should have chromed bolts and flat washers attaching the grab bar to the rear fender.
Dgormley
Way too much
Post by Dgormley » Mon Dec 12, 2011 7:24 pm
Among other things, Kick start indexed wrong, broken spoke, brake stay tab not peened over, water in the headlight, wrong headlight mounting screw, nice bike, just misrepresented..........................D Oh yeah, It's a 66
gopher
Post by gopher » Mon Dec 12, 2011 7:42 pm
Here's my shot:
Lever perches correct - cables wrong
Tank bolt put in backwards
Wrong screws to fasten headlight rim - should be oval heads
Left switch assembly missing one harness band on handlebar, wires routed incorrectly
Black cable tie used to secure rear tail light wires to rear fender brace
Fuel lines look pretty big!
Incorrect rear foot pegs
Rear axle inserted backwards
There shouldn't be a flat washer where the rear fender brace is attached to the fender
Painted fender are correct for this serial number
Cylinder head sealing washers don't look like they are copper
-Gopher
Post by LOUD MOUSE » Mon Dec 12, 2011 7:54 pm
I'm Impressed!
Ya are seeing most of the faults.
I am pleased to see statements which disagree with others as some are correct.
Keep up the answers and I'll do a final in a day or so. ......lm
gopher wrote:Here's my shot:
-Gopher
