Loosening generator rotor bolt?
68Cb77
Post by 68Cb77 » Thu Dec 08, 2011 10:26 pm
I've got starter troubles. I guess the starter clutch rollers have gave out. So, I need to pull the generator. I've tried leaving the chain on, putting it in gear, and trying to loosen the bolt. Is it standard thread, (not backwards, bastard thread?). Would an impact air wrench be better? So far, hasn't come loose.
67 Honda CB77 Superhawk
82 Honda XR200R
70 Honda CB750 K0
68Cb77
Post by 68Cb77 » Thu Dec 08, 2011 10:27 pm
P.S. I've gotten a 16mmX1.5mm thread bolt already to pull the rotor off, as per threads on here.
82 Honda XR200R
70 Honda CB750 K0
Re: Loosening generator rotor bolt?
Post by LOUD MOUSE » Fri Dec 09, 2011 1:04 am
It has a stander thread.
Ya may be able the put a 14mm box wrench on the bolt and SMACK it with a mallet to get the bolt loose. ............lm
68Cb77 wrote:I've got starter troubles. I guess the starter clutch rollers have gave out. So, I need to pull the generator. I've tried leaving the chain on, putting it in gear, and trying to loosen the bolt. Is it standard thread, (not backwards, bastard thread?). Would an impact air wrench be better? So far, hasn't come loose.
68Cb77
Post by 68Cb77 » Fri Dec 09, 2011 9:25 am
Thanks LM, I've been gone awhile, rebuilt a CB750K0 for the last year and a half. Now back to a few things on the Superhawk. I've got a list, Speedo went crazy, have to fix that. new swing arm bushings, have a newer primary chain to go on, going with flat bars, and have to get some good shocks. I'm sure I'll have many more questions. Thanks<john>
82 Honda XR200R
70 Honda CB750 K0
Post by LOUD MOUSE » Fri Dec 09, 2011 10:00 am
Ya welcome. ..........lm
68Cb77 wrote:Thanks LM, I've been gone awhile, rebuilt a CB750K0 for the last year and a half. Now back to a few things on the Superhawk. I've got a list, Speedo went crazy, have to fix that. new swing arm bushings, have a newer primary chain to go on, going with flat bars, and have to get some good shocks. I'm sure I'll have many more questions. Thanks<john>
