Frozen cam lock nut
Bernhard
Re: Frozen cam lock nut
Post by Bernhard » Tue Nov 22, 2011 9:55 am
Bernhard wrote:
Husker45 wrote:Just started restoration on a 1962 cb77. Motor was in a flood 40 years ago. Any thoughts?
If engine was submerged in water then it may have rusted on, you will almost need some heat (depends on how much it has rusted) as well as penetrating fluid Try using shock tactics, that is hitting the bolt with a soft alloy drift and hammer-then using an 8 sided socket –not a muti-corner type or you will round off the bolt edges- sharp taps with a hammer in both, opposite directions at first, then correct direction to loosen it
Husker45
Post by Husker45 » Sat Nov 26, 2011 1:25 pm
Cam nut loosened and cam removed! Thanks for the great advice, but I did not use heat. This nut still has me confused. Does it tighten towards the cam to lock into place (i.e. away from the cam sprocket)?
Post by LOUD MOUSE » Sat Nov 26, 2011 3:26 pm
To the middle of the engine. (into the sprocket). ..lm
Husker45 wrote:Cam nut loosened and cam removed! Thanks for the great advice, but I did not use heat. This nut still has me confused. Does it tighten towards the cam to lock into place (i.e. away from the cam sprocket)?
