CB160 piston rings?
CB160, CB350, CB360, CB450
kalchcliff
CB160 piston rings?
Post by kalchcliff » Fri Aug 26, 2011 1:46 pm
Hello all. I have a set of rings for my CB160. Part # 13020-028-020, .25 over. This set has six rings that look real close to fitting but everything I have found out about them shows for a Honda 90 single cylinder. Any info out there?
Post by davomoto » Fri Aug 26, 2011 3:32 pm
The center code 028 is for an S90. I don't know if they are the correct diameter or thickness for your bike. There must be a forum for the 160s, as they are quite popular as vintage race bikes.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Post by G-Man » Fri Aug 26, 2011 4:29 pm
Hi
S90 and CB160 are the same bore at 50mm. Model code for CB160 is 217. If the rings fit the piston and the bore then you should be fine.
kalchcliff
Post by kalchcliff » Tue Aug 30, 2011 11:21 am
Thanks guys. Will proceed.
roadcapDen
Post by roadcapDen » Fri Nov 11, 2011 10:37 am
The only forum I could find for CB160's was CA racers, not much there?
roadcapDen
2 HD XL's
65 Dream 305
and a bunch of other scoots
brewsky
Post by brewsky » Fri Nov 11, 2011 11:58 am
kalchcliff
Post by kalchcliff » Fri Nov 11, 2011 1:52 pm
Try F-160. CB160 racers mostly on the west coast. Lots of good info.
