Betor forks
Hotshoe
Betor forks
Post by Hotshoe » Tue Sep 13, 2011 9:08 pm
Have any of you fabrication gurus ever installed Betor front forks on a CL77 frame?
If so, how?
If not, any suggestions?
The attached pic looks like Betor forks and triple trees installed on a CL frame.
I'm guessing it has a CL stem adapted to the Betor triple trees.
Thanks, Chuck.
Stock CL frame w Betor forks.
Post by davomoto » Wed Sep 14, 2011 10:09 am
You have to either adapt the CL steerer to the triples, or make a steerer with the CL dimensions. The steerer clamps into the lower triple, so it should not be too difficult to do.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Hotshoe
Post by Hotshoe » Wed Sep 14, 2011 8:07 pm
Thanks Davo, that's pretty much what I was thinking about the Betor forks so I guess I'm headed in the right direction.
That Elsinore/305 is interesting, good eye on the frame.
Did you notice the clutch side case, looks like he removed the oil filter and reshaped the case.
Less spinning mass right on the crank apparently.
Post by davomoto » Thu Sep 15, 2011 9:50 am
Good eye on the clutch case! I'd love to see more pics of all sides of that bike!
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
