Checked Compression
Seanmichaelwood
Checked Compression
Post by Seanmichaelwood » Fri Aug 26, 2011 7:58 pm
So the left piston is holding at under 60 psi. Not looking good. But i guess I am looking for any tips hints or tricks for this terrible news.
jleewebb
valves?
Post by jleewebb » Fri Aug 26, 2011 8:15 pm
sure your valves are adjusted correctly?
'62 CB77. "It's a rider."
Seanmichaelwood
Nope
Post by Seanmichaelwood » Fri Aug 26, 2011 8:56 pm
No that's what I'm aboUt to check. It's .004 gap right ?
Goodysnap
Re: Nope
Post by Goodysnap » Fri Aug 26, 2011 9:20 pm
Seanmichaelwood wrote:No that's what I'm aboUt to check. It's .004 gap right ?
Yes
Did you have throttle and choke full open when you run your test?
If closed it will give false low results.
64' CB77
65' CB160
Seanmichaelwood
Success
Post by Seanmichaelwood » Sat Aug 27, 2011 7:58 pm
All the left side needed was a valve adjustment! Thanks guys
