Racebike Only Thread.
hillhudson
Post by hillhudson » Sat Feb 26, 2011 3:42 pm
G-Man, thanx again, much appreciated.
'65 s90
'64 ca95 dream
'65 cb160
'66 cb77
ricksd
Post by ricksd » Sat Feb 26, 2011 5:45 pm
Airtech makes some long, skinny Honda vintage tanks-
http://www.airtech-streamlining.com/vin ... etanks.htm
Post by davomoto » Sat Feb 26, 2011 6:24 pm
Here's another site.
Davo
http://www.roccitycafe.com/store.php
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
hillhudson
Post by hillhudson » Sat Feb 26, 2011 10:42 pm
awesome! thanks everyone.
can anyone clue me in on another race bike issue ?
http://www.honda305.com/forums/viewtopic.php?t=7040
'65 s90
'64 ca95 dream
'65 cb160
'66 cb77
hillhudson
just got an answer
Post by hillhudson » Sat Feb 26, 2011 11:07 pm
"That figure is the "installed height" of the valve spring. To determine that distance you put one valve at a time in it's position in the head, intsatll the spring seat, the retainer and the keepers. Pull up and hold the valve closed by the the retainer, and measure the distance between the inside of the spring seat (where the spring actually sits) and the underside of the retainer (also where the spring actually makes contact with the retainer). That distance should fall within the 1.380" to 1.420" range. Some builders like to use just the inner spring to help hold the assembly in place while taking this measurement. The enclosed shims are to correct this dimension as required."
'65 s90
'64 ca95 dream
'65 cb160
'66 cb77
hillhudson
Post by hillhudson » Wed Mar 02, 2011 2:25 am
say, quick question, does anyone know of an after market steering damper that just mounts up to the frame of a cb/cl77 ?
'65 s90
'64 ca95 dream
'65 cb160
'66 cb77
GORDON BROWN
steering dampers
Post by GORDON BROWN » Thu Mar 03, 2011 1:53 pm
Hello
Hillhudson, if you reverse? your front engine hanger bolt ( head to L/H, thread on R/H ) you can make up or have made a double ended nut 10mm - 8mm about 40mm long ( a curved tube with 10 / 8 mm nuts welded in the ends works even better ) You can use the cheaper "Kawasaki type" adjustable ones and use the original 8mm hole in the bottom yoke ( triple tree in US ). I think these look quite period and seem to work OK . I am sure you can find a local source for them.
I hope this all makes sense.
Gordon
SAFOJ
