When HONDA assembled the stock engine pistons there was not marking as to size on the top.
Replacement pistons will have a size (STD/.025 etc.) to show the actual size. ...........lm
GeorgeP1111 wrote:Hmmm... I'm not the original poster, but I am looking at the top of my piston now and I see the arrow, but nothing to indicate the piston size. On one of the sides near the pin it says "C77" and on the other side it says "ART", but again, nothing to indicate the size. I measured the piston diameter at 59.95mm so I'm assuming that they are the STD pistons. Also, as for the original rings that were on the pistons, they had a "R" stamped in the top corner, the new ones have "STD", and measuring the ring gaps on the new rings when installed at various heights in the cylinders is within specs so I assume I bought the correct size?LOUD MOUSE wrote:The other member recommended ya clean the top of the piston to look for the actual piston size. With that info we will be able to help a little better. ............lm]
George
