engine blowby
blowby
Sonofabitch! I thought all was well with the Dream. I took it on an extended ride this
morning and the blowby is back with a vengence!
I can feel air blowing from the crankcase vent hose from 5 inches away at idle.
Everything is back together correctly(rings etc.)
Is there a possibility that the oil pump is putting out too much pressure?
Re: blowby
Ya did install the 2 gaskets and metal plate at the top?. ............lm
mike1969 wrote:Thanks Dave,That eliminates another possibility.
Any suggestions?
I would expect there to be significant air flow out the breather hose of a running engine. The crankcase is a sealed vessel of varying volume, and breaths thru that hose. No flow thru that hose means you have a hole in your crankcase somewhere. If there is no smoke coming out of the hose and your compression test is to spec, I would think you are good to go.
regards,
Rob
regards,
Rob
