removing rocker arm pins
houseowax
Post by houseowax » Thu Aug 12, 2010 2:00 pm
Actually, it took me no time at all- maybe 30 seconds apiece. As I had no idea what I was in for I assumed it was going to be tricky, but they all came right out with minimal force. Should it be harder? Sometimes when things are too easy I start to imagine the worst.
As far as compressing my valve springs to remove the retainers... that's HARDER than I imagined, so I guess it all balances out!
'63 CA77 - Giving me all kinds of headaches.
'64 CA77 - Patiently waiting it's turn
'65 CB77 - A 'great winter project'
Post by LOUD MOUSE » Thu Aug 12, 2010 2:16 pm
They aren't tight at all.
The trick is when ya install them later and have to get them in the correct locations. ...........lm
houseowax wrote:Actually, it took me no time at all- maybe 30 seconds apiece. As I had no idea what I was in for I assumed it was going to be tricky, but they all came right out with minimal force. Should it be harder? Sometimes when things are too easy I start to imagine the worst.
houseowax
Post by houseowax » Thu Aug 12, 2010 2:23 pm
Well, I 'bagged and tagged' each one. I hope that's enough. I TRY to pay as much attention to a part's location and special features etc when I'm dismantling, but sometimes I get too caught up in the act and my attention to detail suffers. There's a learning curve here, that's for sure, but I'm getting better all the time. At least...I hope I am.
Post by LOUD MOUSE » Thu Aug 12, 2010 4:30 pm
The secret is to put the right side parts on the left.
That way ya have a smooth surface on the pins at all 4 corners. ......lm
houseowax wrote:Well, I 'bagged and tagged' each one. I hope that's enough. I TRY to pay as much attention to a part's location and special features etc when I'm dismantling, but sometimes I get too caught up in the act and my attention to detail suffers. There's a learning curve here, that's for sure, but I'm getting better all the time. At least...I hope I am.
houseowax
Post by houseowax » Thu Aug 12, 2010 5:18 pm
Ah-HA!
It's been said here before, but it bears repeating: there's no substitute for experience. Thanks as always, LM.
Post by LOUD MOUSE » Thu Aug 12, 2010 5:21 pm
For sure ya won't find that info in any book. ........lm ............lm
houseowax wrote:Ah-HA!
teazer
Post by teazer » Thu Aug 12, 2010 5:42 pm
The key is that intake pins and exhaust pins have 0.5mm difference in diameter IIRC.
Where the rocker arms ride is the same, but where they go into the head is different. On engines that have been torn down a few times the holes often end up slightly oversized from fitting the wrong pins.
