Bad horn
eyhonda
Bad horn
Post by eyhonda » Wed Jun 09, 2010 2:35 pm
I have a cb77 horn that just stopped working. Is it possible to rebuild them or is it serviceable?
63 cb77 cafe
www.eyhonda.com
jleewebb
horn repair
Post by jleewebb » Wed Jun 09, 2010 3:15 pm
Hi Eric...
I managed to repair my horn:
http://www.honda305.com/forums/viewtopi ... &highlight
Yours may have a different problem, but taking it apart and figuring out how it's supposed to work would be a place to start.
The dome part just pries off, best i can recall.
good luck, Lee
'62 CB77. "It's a rider."
eyhonda
Post by eyhonda » Wed Jun 09, 2010 4:33 pm
Thanks, Lee. I'll try to inspect it more when I get a chance. I wasn't sure how to pry it open in the first place.
63 cb77 cafe
www.eyhonda.com
Wilf
Post by Wilf » Wed Jun 09, 2010 5:57 pm
These CB77 horns are easily serviced/repaired and there should never be any reason to throw one out--they should last hundreds of years!
Are you sure it's the horn that is the problem? The switch and wiring connections would be my first suspects.
Wilf
eyhonda
Post by eyhonda » Wed Jun 09, 2010 10:28 pm
The wiring is ok since it is working with a temporary horn from a cb175. Anyway, I just got it working! Thanks for all the responses! Great forum! I'm glad I didn't sell it. I just popped it open and tapped it few times and some debrie (sp?) fell out. Then I adjusted the nut for a better tone. Cool! It was surprisingly clean inside too.
63 cb77 cafe
www.eyhonda.com
Wilf
Post by Wilf » Wed Jun 09, 2010 10:56 pm
Ah, that's nice to hear! The last horn I shook had a colony of dead sow bugs and some grit, but after shaking out the debris, it worked fine!
Wilf
Wilf
Post by Wilf » Wed Jun 23, 2010 9:31 pm
I take back my second-to-last post! I opened up this spare horn yesterday to see if a broken wire or pitted points were the cause of its failure to make noise...
I'm not sure I will be able to get this working really soon...
Wilf
