primary drive sprocket removal
scooterjunkie
Post by scooterjunkie » Sat Apr 03, 2010 5:04 pm
Anyone have a sneakey trick to remove the nut securing the primary drive sprocket? I'm trying to remove the whole assembly with the clutch basket. Clymer leaves alot of minor details out of the manual...
Re: primary drive sprocket removal
Post by LOUD MOUSE » Sat Apr 03, 2010 6:48 pm
Ya will see a locking washer with lots of WINGS and one should be hammered into one slot of the large nut.
Bend the wing out so ya can now using a soft chisel sort of tool and knock/hammer it counter clockwise to loosen/remove it. ............lm
scooterjunkie wrote:Anyone have a sneakey trick to remove the nut securing the primary drive sprocket? I'm trying to remove the whole assembly with the clutch basket. Clymer leaves alot of minor details out of the manual...
scooterjunkie
Post by scooterjunkie » Sat Apr 03, 2010 7:48 pm
Any decent/safe way to block the sprocket from spinning whilst I wail away?
Post by davomoto » Sat Apr 03, 2010 8:53 pm
You shouldn't need to, but if you must, a penny between the chain and gears works well.
scooterjunkie
Post by scooterjunkie » Sat Apr 03, 2010 10:10 pm
Thanks Davomoto!
LM: I'm still gathering the materials to ship the head to you...
