Eljeef
Post
by Eljeef » Wed Jul 15, 2009 2:57 pm
Howdy. Does anyone have a good handlebar for my Dream with the slots for wiring? Thanks, Jeff.
, , Pictures are kinda busy...hope you can make out the details. My bar is bent and has splits where the oval cut-outs are for wire routing. I could weld them if I have to but I would rather replace them. Thanks, Jeff.
- h305 Moderator
Post
by e3steve » Wed Jul 15, 2009 5:04 pm
What's your market - i.e. where are you based? That would've been a CA77 in UK, with that handlebar. Those trafficators (winkers) possibly indicate (no pun!) GB/Ca/D(or other N. Europe market)/Jp/Au.
Trawl eBay; similar 'bar to CA95/CA160 with winkers, I think you'll find. Leastways, a good substitute.
G'luck!
Eljeef
Post
by Eljeef » Wed Jul 15, 2009 7:25 pm
e3steve wrote:What's your market - i.e. where are you based? That would've been a CA77 in UK, with that handlebar. Those trafficators (winkers) possibly indicate (no pun!) GB/Ca/D(or other N. Europe market)/Jp/Au.
G'luck!
Hello. I'm in Canada eh'. My handlebar has six holes for various wires and cables. Actually there is one on the bay right now that is the U.S. version with four holes. I was thinking that perhaps I could cut the holes out for the winkers. What do you think? Jeff
- h305 Moderator
Post
by e3steve » Thu Jul 16, 2009 4:00 am
Piece o' cake, Jeff:
- Centre-punch the bar in the appropriate places -- an extra pair of hands is useful to steady the 'bar on a block of wood on a concrete floor (not a wooden floor; the datum of a concrete floor will resist the impact of the punch; that way you won't have to hit the punch too hard)
Start with a small drill bit -- 3mm/⅛" and work your way up to 10mm/⅜"
De-burr the final aperture using the point of a sharp knife (not a modelling / Stanley knife!) -- tape up the blade, leaving just the point exposed, and wear heavy gloves
Treat the bared metal with silicon grease or, as a good second choice, WD40 -- essential in order to avoid the plating being undermined further in the future
Cinch!
Eljeef
Post
by Eljeef » Thu Jul 16, 2009 8:08 am
e3steve wrote:Piece o' cake, Jeff:
Cinch!
Thanks. Maybe I'll give that a go and then I could get it chromed to treat the metal. Regards, Jeff.
