Removing CB77 front fork seal covers
rappaj17
Post by rappaj17 » Tue Jun 16, 2009 10:36 pm
Would anyone happen to know how to remove the chrome fork seal cover from the front shocks of an early model CB77? The late model forks with the aluminum bottoms seem to slip right off with some twisting power, but I can not seem to get the covers off of the early model forks with the steel painted bottoms. I would imagine that the four divots around the outside of the chrome cover are for some kind of tool? I tried a belt wrench but had no luck.
jleewebb
strap wrench
Post by jleewebb » Wed Jun 17, 2009 7:54 am
There is indeed a special tool, some folks have made their own. You might try adding a hose clamp to your strap wrench to make it clamp down tighter, it worked for me. See pix. I slipped a small piece of plastic (cut up sample credit card) in to pad part where hose clamp could have marred chrome. Whole story in my restoration thread. Good luck, Lee
Careful not to squeeze tube too tight in vise, clamp it down near where axle goes through.
Nasty looking but it worked.
'62 CB77. "It's a rider."
Kirk
Post by Kirk » Wed Jun 17, 2009 11:40 am
I have been running into the same issue as you here is what I did.
Check around the threaded side and make sure it is not bent, Then soak the top and bottom with penetrating oil Like PB Blaster. Soak two or three times over a couple of days. Make sure to wipe the excess oil off or the wrench will just spin, you may have to use some soap and water. Then use a rubber strap wrench (it has more grip) DO NOT PUT THE FORK LEG IN A VISE LIKE IN THE PREVIOUS PHOTO. You will most likely damage it. Put only the part where the axle goes through you will have to hold up the other end. Then try the rubber strap wrench, make sure you are turning the right direction. I tightend one even tighter once. (Whoops) Here is a post on the tool. Thanks Randall On the tool Construction
http://www.honda305.com/forums/viewtopic.php?t=2142
and a photo of a similar strap wrench I use.
Thanks,
Kirk
Mine is similar to these
2-1966 CB77 Projects
1965 CB77 Partsbike
1967 scrambler pile of parts
1972 Cb350
Spargett
Re: Removing CB77 front fork seal covers
Post by Spargett » Wed Jun 17, 2009 6:07 pm
What's the pattern with the lower portion of the fork being painted silver. I've seen alot of that and it's always puzzled me.
rappaj17 wrote:The late model forks with the aluminum bottoms seem to slip right off with some twisting power, but I can not seem to get the covers off of the early model forks with the steel painted bottoms.
rappaj17
Post by rappaj17 » Wed Jun 17, 2009 11:15 pm
After breaking one rubber strap wrench, I tried another one and got the chrome cover off by clamping the bottom axle part of the shock in a vice. Thanks for the help.
Now that I have the bottom of the shocks separated I am going to have them powder coated red. I'm doing the red/silver color scheme and I think the original color for the bottoms of the shocks is red. I guess I could see painting them silver if you want to make them look like the aluminum style bottoms.
Post by LOUD MOUSE » Thu Jun 18, 2009 7:44 am
Steel - frame color.
Aluminum - silver. ...........lm
Spargett wrote:What's the pattern with the lower portion of the fork being painted silver. I've seen alot of that and it's always puzzled me.
Spargett
Post by Spargett » Thu Jun 18, 2009 2:29 pm
What determines which bikes have the bare aluminum or not? Was that never stock?
LOUD MOUSE wrote:Steel - frame color.
