CB160 Turns Over forever before starting....
CB160, CB350, CB360, CB450
bigscooter
Post by bigscooter » Sun Aug 24, 2008 10:20 am
is that spark across the actual plug gap? recently i had a similar problem that turned out to be fouled plugs. it was a tuff troubleshoot cuz the plugs looked clean and new.
brooklynCB
Post by brooklynCB » Tue Aug 26, 2008 8:34 pm
Man-- I've had new plugs, sanded off old ones, etc. The spark looks good when I take it out. Thing just wont start. couple huffs and puffs when getting on the starter for a while, but nothing more.
eyhonda
Post by eyhonda » Mon Mar 23, 2009 2:46 pm
are you sure the pilot jets are clear?
eyhonda
Post by eyhonda » Mon Mar 23, 2009 2:47 pm
is it possible to have the timing 180 degrees off?
Post by davomoto » Mon Mar 23, 2009 3:05 pm
Are the slide in the correct sides? The cutout at the bottom of the slide must face rearward, toward air filter. Another thought is float level set correctly?
