cb77 rear shock/sprocket clearance
Gun
Post by Gun » Fri Jun 27, 2008 8:42 pm
Well i took the best camera phone picture i could. Hope it shows what i'm having an issue with.
It would appear that those bolts on the sprocket are too close to the swingarm/tip of the rear shock. If i try to put any bolt/nut there to hold that guy on, it touches. am i missing a spacer on the sprocket side that should be on that rear axel? or what?
any ideas?
'65 CB77
'66 CB450k0
'93 HD FXR
Gun
Post by Gun » Fri Jun 27, 2008 8:48 pm
ah... i'm thinking that i just have the order of operations backwards, seems like the head of the screw goes in from the inside, and this is done before the back tire etc, is finalized.
is that correct?
'65 CB77
'66 CB450k0
'93 HD FXR
Post by LOUD MOUSE » Sat Jun 28, 2008 7:20 am
You will find when you install the chrome adjuster that there will be a small amount of clearance added and that bolt has a very thin head compared to most. ...........lm
Gun wrote:ah... i'm thinking that i just have the order of operations backwards, seems like the head of the screw goes in from the inside, and this is done before the back tire etc, is finalized.
is that correct?
RIDE IT DON'T HIDE IT!
Gun
Post by Gun » Sat Jun 28, 2008 12:09 pm
thanks, now if only the old bolt wasn't so stripped. If i had a drill press or something, i'd imagine i could rethread it and use a smaller nut or something... but yeah, no such resources. guess i'll have to order one, hope the honda dealership in town has em.
'65 CB77
'66 CB450k0
'93 HD FXR
Gun
Post by Gun » Sat Jun 28, 2008 3:45 pm
ordered part number 0051250 from the honda dealership.
how they manage to charge 8 bucks for a bolt is beyond me.
'65 CB77
'66 CB450k0
'93 HD FXR
Post by LOUD MOUSE » Sat Jun 28, 2008 9:03 pm
Better parts number please. ...........lm
Gun wrote:ordered part number 0051250 from the honda dealership.
Gun
Post by Gun » Sat Jun 28, 2008 11:09 pm
not sure what to give you, let me show you what i nabbed off of powersportspro and gave to the guy, he confirmed it was for the rear shock absorber.
SKU: 90107-268-000
BOLT, SHOCK ABSORBER (LOWER) (Honda Code 0051250) (NOT AVAILABLE)
is what its listed as there. so i just took that honda code into the store and they put it on order.
'65 CB77
'66 CB450k0
'93 HD FXR
