Can this stand be saved
gac123
Post by gac123 » Fri May 02, 2008 8:19 pm
As I started to disassemble my "find" I noticed that on one side it was sitting not on the stand but instead on the outrigger. It doesn't look bent but must be. Any hints on how and how much to bend it back. i assume that heat will be involved.
Greg
FluteTears
Post by FluteTears » Fri May 02, 2008 9:20 pm
Nope see no problem with it that bend is part of the toe kick to put your foot on.
Brad
1974 CT90
1964 CA77
gac123
Post by gac123 » Sat May 03, 2008 8:09 pm
So, why didn't the bike sit on the right foot ( as seen in the picture)? I don't believe that the stand should be able to stand up by itself. Wouldn't a normal stand fall backward?
Greg
FluteTears
Post by FluteTears » Sun May 04, 2008 8:47 am
Oh well you have a point but I cant see that in the photo and I am not sure if mine would stand or not looking at it edge wise is should be flat and not one steped out and one steped in if so yes id put it in a vice and heat it up and twist it back maybe use a pipe over it.
Sorry I thought you was looking at the toe kick its a little bent down I think but not bad.
Brad
1974 CT90
1964 CA77
FluteTears
Brad
1974 CT90
1964 CA77
