Thanks for the clarification.
There are two 8mm studs rising vertically from the under crankcase and through the upper crankcase, secured by hex nuts in the upper crankcase well under the latched/removable upper crankcase cover. Loosen those hex nuts to be flush with the stud threads and tap-tap the studs. It may help the crankcase separating process.
