Piston size is it written on top or side ??
fab
Post by fab » Tue Nov 01, 2005 3:33 am
Hi <br /> fellow dreamers !! I going to pull my head off tonight while I have the motor already out . I want to put a new chain in while it's out &amp; just have a look in the bores . Maybe wack a set of rings in it if needed etc etc. Can one of you Guy's please tell me where the size is written as I might not have to pull the bores all the way off to read the size depending where it is written I'm hoping it's on top ? Is the sizing easy to identify by there number system .<br /> All the best Peter
Re: Piston size is it written on top or side ??
Post by LOUD MOUSE » Tue Nov 01, 2005 9:46 am
It is on top. No numbers is STANDARD, 25 is first 50 is second 75 is third and 1.00 is forth (last Honda). .............LM
RIDE IT DON'T HIDE IT!
fab
Post by fab » Wed Nov 02, 2005 7:15 am
LM Thanks !!!!<br /> I took the head off &amp; it appears it's STD . It has no numbers on the top of the piston , But on the side of the piston it says c77 . So it looks standard bore. It has had new rings recently as the bores still have vivid honing marks .<br /> Thank you once again for your info / Peter
Post by LOUD MOUSE » Wed Nov 02, 2005 7:22 am
You are welcome Peter. ..............LM
cron
