Torquing CA77 Head Bolts
Dogsbd
Post by Dogsbd » Mon Jun 30, 2008 1:20 pm
It looks the same, in that it is installed with the correct end exposed. It seems that it is either too long, not seated as deep as it should be in the case end or stretched.
Post by LOUD MOUSE » Mon Jun 30, 2008 1:38 pm
Install the one you have out and compare the amount of threads. I've at times had to 3 nut to remove studs. .......................lm
Dogsbd wrote:It looks the same, in that it is installed with the correct end exposed. It seems that it is either too long, not seated as deep as it should be in the case end or stretched.
RIDE IT DON'T HIDE IT!
Dogsbd
Post by Dogsbd » Mon Jun 30, 2008 3:22 pm
Reinstalled the right one. When fully seated the end of it is about 1/8" lower that the two center studs and the left one is about 3/16" to a 1/4" higher than the center studs.
Tried 3 nuts, still no joy. Locked them all together as tight as I could and when I start turning on the bottom one to back out the stud they all turn once I really apply pressure.
Post by LOUD MOUSE » Mon Jun 30, 2008 3:31 pm
The corner studs will be shorter than the center ones with the top removed.
As I recall the problem was "won't torque to value. So I'd say that if it won't come out I'd use a tool "I have several" and cut off/remove any excess thread length of that stud and get back to where ya was headed. Those corner studs have been one problem or another since I've been working on these engines but it's usually they break off when ya try to remove them. ...................lm
Dogsbd wrote:Reinstalled the right one. Fully seated the end of it is about 1/8" lower that the two center studs and the left one is about 3/16" to a 1/4" higher than the center studs.
Dogsbd
Post by Dogsbd » Mon Jun 30, 2008 4:10 pm
LOUD MOUSE wrote: So I'd say that if it won't come out I'd use a tool "I have several"
What sort of tool are you referring to??
(this is sounding better than I feared!!!!)
Post by LOUD MOUSE » Mon Jun 30, 2008 5:50 pm
I have carborundum wheels for my air tools and DREMEL makes a cut off wheel for their tools. ..........lm
Dogsbd
Post by Dogsbd » Mon Jun 30, 2008 6:15 pm
LOUD MOUSE wrote:I have carborundum wheels for my air tools and DREMEL makes a cut off wheel for their tools. ..........lm
OHhhh... got ya.
I think I can come up with something for the Dremel. ;)
Thanks for all your help!
cron
