engine blowby
Post by davomoto » Thu Sep 23, 2010 7:13 pm
Happy to help!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
mike1969
blowby
Post by mike1969 » Sun Sep 26, 2010 11:55 am
Got the motor assembled and back on the bike. I'm happy to say that the blowby is gone!
Thanks to everyone who helped with advice.
I still have to re-torque the head bolts.(thanks for that tip also)
mike1969
blowby
Post by mike1969 » Sun Oct 10, 2010 12:05 pm
Sonofabitch! I thought all was well with the Dream. I took it on an extended ride this
morning and the blowby is back with a vengence!
I can feel air blowing from the crankcase vent hose from 5 inches away at idle.
Everything is back together correctly(rings etc.)
Is there a possibility that the oil pump is putting out too much pressure?
Post by davomoto » Sun Oct 10, 2010 8:45 pm
Mike, no these oil pums have minimal pressure.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
mike1969
blowby
Post by mike1969 » Mon Oct 11, 2010 6:53 am
Thanks Dave,That eliminates another possibility.
Any suggestions?
Re: blowby
Post by LOUD MOUSE » Mon Oct 11, 2010 7:21 am
Ya did install the 2 gaskets and metal plate at the top?. ............lm
mike1969 wrote:Thanks Dave,That eliminates another possibility.
Any suggestions?
Snakeoil
Post by Snakeoil » Mon Oct 11, 2010 8:45 am
I would expect there to be significant air flow out the breather hose of a running engine. The crankcase is a sealed vessel of varying volume, and breaths thru that hose. No flow thru that hose means you have a hole in your crankcase somewhere. If there is no smoke coming out of the hose and your compression test is to spec, I would think you are good to go.
regards,
Rob
