cb 77 engine stuck???
Post by LOUD MOUSE » Wed Oct 13, 2010 9:57 am
What in the world????????????.
Also thanks for the pics. Have an of the filter and chain and outer clutch basket?. .........lm
waynew wrote:L M i have taken some digital pictures and am now going to try to figure out how to post them. the screws you mentioned are in the shifter area (how did u know that?) but the other 6 screws i removed from the c-case cover were phillips head.
waynew
Post by waynew » Wed Oct 13, 2010 10:03 am
L M are you asking if i have a pic of the oil filter, chain, etc?
Post by LOUD MOUSE » Wed Oct 13, 2010 10:39 am
Yep.
If ya can will ya show all the parts which show damage and the loose screws also.
Will the engine turn over now?. ........lm
waynew wrote:L M are you asking if i have a pic of the oil filter, chain, etc?
waynew
Post by waynew » Wed Oct 13, 2010 10:58 am
L M, the only damaged part i've found thus far is the area where the oil filter shaft goes into the c-case (as shown in the 2 pictures). Oil filter, chain, etc. seem fine. I have not accessed the clutch area yet due to 2 p-h screws that are gouged-out in the c-case cover. as far as "loose" screws i've not come across any of them YET!
Post by davomoto » Wed Oct 13, 2010 11:07 am
Wayne, a good way to remove those stripped screws is with a center punch. Hit the punch straight into the screw head until you make a nice divot. Then slowly angle the puch more asnd more, until the screw breaks loose. Obvoiusly the screw is trahed at this point, but it was shagged already anyway.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
waynew
Post by waynew » Wed Oct 13, 2010 11:12 am
Thank you sir. I'll give that trick-a-try.
Post by LOUD MOUSE » Wed Oct 13, 2010 11:15 am
I misread a previous message about the screws. ...............lm
waynew wrote:Thank you sir. I'll give that trick-a-try.
