Oil filter O Ring
Chris Jensen
Oil filter O Ring
Post by Chris Jensen » Fri Jun 11, 2010 10:04 pm
I took my oil filter apart to clean it and the O ring is broken . Where can you find a replacement and will it cause an oil pressure drop or damage to run the engine with out it? thanks Chris
Post by davomoto » Sat Jun 12, 2010 10:29 am
Chris, try a hydraulic repair / supply shop. The have o-rings up the wazoo, and can possibly find one to fit.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
brewsky
Post by brewsky » Sat Jun 12, 2010 1:41 pm
If you can't find one local, try this site:
https://www.oringsusa.com/catalog/index ... rhu8es1f10
Chris Jensen
Post by Chris Jensen » Mon Jun 28, 2010 9:42 am
Thank You for the help. I found one at a lawn mower repair shop. It's a carb bowl gasket .
