starter brushes
thumper2146
starter brushes
Post by thumper2146 » Sun Jun 06, 2010 11:26 am
has anyone found a non honda set of brushes that will fit cb72/cb77 starters? i found some on ebay but at 24.00 each seams kinda steep to me
Post by e3steve » Sun Jun 06, 2010 3:57 pm
Have you stripped yours out and inspected? You'll more than likely not need to replace them unless their free length is less than 8-10mm. Or unless the power wires have broken.
thumper2146
starter
Post by thumper2146 » Sun Jun 06, 2010 4:15 pm
yes had them out but there just a tad short while i had it apart i also chucked it up in my mini lathe and cleaned trued up the communtator and undercut the mica starter has much more power than before
e3steve wrote:Have you stripped yours out and inspected? You'll more than likely not need to replace them unless their free length is less than 8-10mm. Or unless the power wires have broken.
Post by e3steve » Mon Jun 07, 2010 2:30 am
Good call; undercutting is an important aspect that often gets overlooked, thus causing unnecessary arcing and commutator / brush 'burning'. These brushes actually rarely need replacement, but $25/pair is about the going rate for our relatively rare copper-graphite items.
Forum member FAST FRED KOREN advised me, a while back, that Ohio Cycle stocks both Kokusan and Denso brushes at that price. There's usually a brass manufacturer's plate on the motor body.
G'luck!
