I installed a Kohler Reg/Rect yesterday on my 66' scrambler and found with a test light the unit is hot with the key in off position.
The kohler has 3 tabs and the middle tab has + on it so I connected the red/hot wire there.
Is that correct to be hot all the time?
Regulator/Rectifier
Regulator/Rectifier66' CL77, 63' CB77, 73' Jawa 350/ model 362 Californian 65' Jawa 250/model 590 07' Moto-Guzzi 1100 Griso
Not having the schematic in front of me to read, I'd assume that you're correct.
Sounds like you may have tapped directly from the positive side of the battery for a power source and before the ignition switch which would make it hot all the time. Try to find a power source that is after the ignition switch, that way when the key is on you have power and when the key is turned off, the power at the rectifier is off as well. I don't know what the wire gauge requirements are for the rectifier, but if you look at a wiring diagram, I bet you'll find a suitable power source. Hopefully somebody with a little more knowledge will chime in. Good luck.
