handle bars
william
handle bars
Post by william » Thu Dec 31, 2009 8:57 am
were can you buy new handle bars 1966 ca77
Post by 305 » Fri Jan 01, 2010 7:55 am
i see them on Ebay sometimes , you may also want to check with Ohio Cycle..i see he has them for $155
http://www.ohiocycle.com/
when small men begin to cast long shadows it's a sure sign the sun is setting
Re: handle bars
Post by e3steve » Sun Jan 03, 2010 10:51 am
william wrote:were can you buy new handle bars 1966 ca77
I believe this handlebar is for C & CA72s/77s/78s
http://cgi.ebay.com/ebaymotors/HONDA-CB ... ccessories
I think the seller has his wires crossed; CBs never had a handlebar with a reduced diameter at the throttle!
brewsky
Post by brewsky » Sun Jan 03, 2010 6:49 pm
There are (at least) two different bars for the CA77's:
early type with conventional (wrap around) throttle contol..it has a raised notch to set the bars in the holder...and
late type .....no raised notch, and has slot cut in the right hand grip side for the recessed sliding throttle control mechanism. The late type also has a hole cut in the bar to allow the throttle cable to exit the right side of the bar.
You will want to get the correct one if you want to retain the existing throttle cable set-up.
I have yet to find anyone with a new OEM Honda "late" handlebar available.
I have seen some used occasionally on e-bay.
Part #'s: Early....53100-281-000
Late....53100-272-000...(superceded to 531-272-335)
Post by e3steve » Mon Jan 04, 2010 3:37 am
Great info, Brew! Nice one!
Post by G-Man » Mon Jan 04, 2010 5:52 pm
William
How about these? Clearly not BSA or Triumph with that slot for the throttle.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 910wt_1158
brewsky
Post by brewsky » Mon Jan 11, 2010 5:14 am
This appears to be the correct bar.
http://cgi.ebay.com/ebaymotors/Honda-Dr ... 4ced09176d
