Figured out my kick start issue
Figured out my kick start issueI knew going into this build that the kick start wasn't working. Since it hasn't run in 35 years I figured the spring in the ratchet system was bad. I was wrong. I'm guessing the bearing went bad and caused the shaft to seize. It got hot enough the gears on the shaft are seized. Now the hunt for a transmission.
20180531_214810 by listen2this1, on Flickr 20180531_215813 by listen2this1, on Flickr 20180531_222054 by listen2this1, on Flickr
Re: Figured out my kick start issueYep - you definitely need a new gearset!
Check out all of the oilways and the filter before you reassemble. Did it have enough oil in it? Can you tell if there was a full set of rollers? How about the crankshaft? G
'61 CB72 '64 CB77 '65 CB160 '66 Matchless 350 '67 CL77 '67 S90 '77 CB400F Saw exactly the same on my elder brothers cb72 in 1966, it was 1 year old and well maintained. Fortunately we now know that if the kick start moves forward when the engine is running it's a sign that the shaft and bearings are probably starting to wear and need attention.
As G said, make sure there's no debris in the oilways and the crank. Good luck with it. Al.
Not sure about the oil. It had a good amount in it when I drained it but that was from 35 years ago. I had another set of eyes look over it and everything else appears to look good and have all the correct pieces. We did find a couple pieces or metal in the pan. Going to look over again tonight.
Any tricks or tips on how to clear the oilways? I use pipe cleaners (soaked in solvent) and teapot brushes, but I am English. :-)
https://www.ebay.co.uk/itm/Mini-Bristle ... Sw8HBZGV8G https://www.ebay.co.uk/itm/White-Flexib ... SwOy1aqPxl G
