Rear Fender Collar
Rickytic
Rear Fender Collar
Post by Rickytic » Fri Mar 15, 2013 11:55 pm
After looking at the parts fiche for the rear fender on the CL77, I see there is a right side collar that goes inside the fender and through the rubber gromet through which a bolt and nut attaches the fender and the grab rail, part number 33609-283-670.
Question, when I took my bike apart there was only one collar and it was on the left side, is there supposed to the saame collar on both sides? If so, I am looking for another collar if anybody has one for sale, please let me know.
Rickytic
Re: Rear Fender Collar
Post by LOUD MOUSE » Sat Mar 16, 2013 10:37 am
If your fender has a hole larger than a 8mm bolt you do need the part and a rubber sleeve for it to fit into. ...lm
Rickytic wrote:After looking at the parts fiche for the rear fender on the CL77, I see there is a right side collar that goes inside the fender and through the rubber gromet through which a bolt and nut attaches the fender and the grab rail, part number 33609-283-670.
Rickytic
Rickytic
Post by Rickytic » Sat Mar 16, 2013 9:58 pm
Thanks Ed, the fender is the large hole variety. I put the 3/4 od/1/2id gromett in the fender which takes the collar just fine. Only have one collar so will build one or find one online/forum. Will not be using the muffler, will go with snuff-or-nots like my original bike in 66.
Rickytic
Rickytic
Post by Rickytic » Fri Mar 22, 2013 10:15 am
Ed, I have two rear fenders, one has the small holes with the welded nuts on it, and the other one has the large hole. I have prepared and painted the large hole fender and have it installed. Question, which fender is correct for the 66 CL77?
Rickytic
Post by LOUD MOUSE » Fri Mar 22, 2013 10:48 am
Depends on the frame number.
1033481 is the last one to use the small hole/nut fender (2 hole license plate bracket). .....lm
Rickytic wrote:Ed, I have two rear fenders, one has the small holes with the welded nuts on it, and the other one has the large hole. I have prepared and painted the large hole fender and have it installed. Question, which fender is correct for the 66 CL77?
Rickytic
Rickytic
Post by Rickytic » Fri Mar 22, 2013 12:49 pm
Thanks Ed.
