Pistons?
Pistons?Has anyone had experience with Kenig pistons? All that I know is that they were an aftermarket piston for racing applications with a 10.5:1 compression, when cb77s were on the tracks.
Also, I need some .25mm and .75mm rings for some cb77 pistons I have. Thanks, Dick
Are these then high compression pistons that must have working clearances set because they are domed so high? Didn't the early Super Hawks have a higher compression ratio than the later models? Was there a reason Honda decreased the CR?
