Brickyard wrote:G,
I cant accurately measure all areas in the cylinder as I dont have a micrometer, however, my digital caliper allows me to measure 1/4 inch from the top and bottom of the cylinder. My results are as follow:
Squealing noise around stator and slow return to idlesBefore completely patching the engine up, my memory kicked in:
Im used to the crankshaft being almost spring loaded (compression stroke?) at TDC making it damn near impossible to hold at T without a rigged wrench. This time, this spring loaded feeling is 180 degrees off at LTDC. My cam sprocket mark is pointed up, the line on the points cam is pointed up, and my crank is at at T before installing the cam chain. Am i missing something?
Have you adjusted all the rockers?. .......lm
Didn't touch them. The head was fine before the teardown.
Must have been some job to get the chain on the sprocket.
You didn't get the same "T" as you came around?. .......lm
