Where is the CL77 crankcase vent/breather
Snakeoil
Post by Snakeoil » Wed Sep 09, 2015 8:06 pm
Yes, confirmed the head mounted vent. And yes I agree that the port on the right case under the side cover is for dumping water that collects in the valley under the tin cover.
Thanks,
Rob
rrietman
Post by rrietman » Wed Sep 09, 2015 9:14 pm
There is, also an approx 1/8" hole above and slightly aft of the countershaft sprocket. goes from inside the side cover to outside air. never have figured out what that is there for. knowing Honda, there is some purpose. doesn't appear to be a manufacturing thing so?
Randy
Post by LOUD MOUSE » Thu Sep 10, 2015 4:06 am
Pic?. .....................lm
rrietman wrote:There is, also an approx 1/8" hole above and slightly aft of the countershaft sprocket. goes from inside the side cover to outside air. never have figured out what that is there for. knowing Honda, there is some purpose. doesn't appear to be a manufacturing thing so?
Randy
Snakeoil
Post by Snakeoil » Thu Sep 10, 2015 1:54 pm
Well, I need to eat a little crow here. Although that hole near the primary does dump water out of the valley, it is also where the crankcase vent line should be routed. The oil vapor will oil the chain. I'm back home and pulled the tin cover off the engine and sure enough, mine is routed to that hole.
Funny how you forget details like this when you don't work on them all the time (and have gray hair).
regards,
Rob
G3
Post by G3 » Thu Sep 10, 2015 11:15 pm
Ahhh Rob!
Too funny! It gets us all when we least expect it.
