Dream chain size snafuDream chain size snafuAfter buying a chain 520-96 links for my 1965 ca77 found it doesn't fit my sprockets.
Purchased it more than a year ago so I can't send it back. Anyone have an idea as to what went wrong?
chain snafuRe-read the post on chain size. From what I read 520 and 525 have different widths. My problem is the teeth of the sprockets don't mesh with the chain.
I can now see the chain is too narrow. Will the wider chain also mesh better? Is it possible that the sprockets are a different pitch? Don't want to order the wrong chain again. I'm confused. How is the sprocket?Chains and sprockets wear out. As the chain wears it gets longer and the sprocket teeth wear to fit the chain. Perhaps your sprocket is as worn out as the chain you are replacing and should be replaced also.
Fast Fred 65 CL77
66 CL77 76 CB550FKR 76 CT90 chain snafuThe sprockets do look a little on the worn side. The chain won't fit down into the sprockets. Want to get the bike on the road to see how it shifts before I sink money into sprockets, but I guess I might have to.
