Dream chain size snafu
mike1969
Post by mike1969 » Thu Aug 21, 2014 9:28 pm
After buying a chain 520-96 links for my 1965 ca77 found it doesn't fit my sprockets.
Purchased it more than a year ago so I can't send it back.
Anyone have an idea as to what went wrong?
OldStan
Post by OldStan » Thu Aug 21, 2014 10:22 pm
Stock chain size is 525.
63 CA78
mike1969
chain
Post by mike1969 » Fri Aug 22, 2014 7:31 am
Thanks Stan, I'll order a 525 chain . I researched the posts and found out it was my fault. It mention 520 and 525 chains. Guess I mis-read.
Anyone need a new 520-96 chain?
Mike
mike1969
chain snafu
Post by mike1969 » Fri Aug 22, 2014 3:03 pm
Re-read the post on chain size. From what I read 520 and 525 have different widths. My problem is the teeth of the sprockets don't mesh with the chain.
I can now see the chain is too narrow. Will the wider chain also mesh better? Is it possible that the sprockets are a different pitch? Don't want to order the wrong chain again. I'm confused.
cadman
Post by cadman » Fri Aug 22, 2014 4:01 pm
The "pitch" (distance between the rollers) on 520 and 525 chain is the same.
FAST FRED
How is the sprocket?
Post by FAST FRED » Fri Aug 22, 2014 4:54 pm
Chains and sprockets wear out. As the chain wears it gets longer and the sprocket teeth wear to fit the chain. Perhaps your sprocket is as worn out as the chain you are replacing and should be replaced also.
Fast Fred
65 CL77
66 CL77
76 CB550FKR
76 CT90
mike1969
chain snafu
Post by mike1969 » Fri Aug 22, 2014 9:12 pm
The sprockets do look a little on the worn side. The chain won't fit down into the sprockets. Want to get the bike on the road to see how it shifts before I sink money into sprockets, but I guess I might have to.
