I made the mistake of taking the ignition switch (CA77) apart to see if it was clean. Little did I know there were all these little triangular pieces.
There is a picture of how they go back in on this site but that way does not seem to work. I have tried several different positions without much luck. Does anyone have a picture or additional info on reassembling this switch.
Thanks - Don (Cadman)
Ignition Switch Assembly HelpMore wiringThe first problem is that all the wiring diagrams I have show a black/yellow from the tail light pin on the back of the switch. I have two ignition switches both have a white wire for the tail light which follows all the way back to the light.
Anyone got a diagram with the white wire?? Here's a pic of the backside of the switch.
