timing or sticky valve-smoke out of carb
timing or sticky valve-smoke out of carbWell, I finally got it running after carb and petcock rebuild - newly acquired 1967 cl77. They really are great sounding bikes...
BUT, I am getting back pressure coming out of the right side carb. I have been adjusting the timing using lm's method, but to no avail. Then I started thinking that it may be a stuck valve. Is there any chance of this is or is the timing more likely? Also, my original needles were badly pitted so I am using the jets and needles from the Keyster kit. I have read here that they are no good, but not why. What are the issues with them? Any help is greatly appreciated. Thanks.
Well after the wife and kids went to bed I looked at the valves and all looked good. After the baby woke up this morning I was able to fire it up again and it is only firing on one cylinder. Hopefully just issues with the Keyster carb kit. I know that the floats are a bit high, so maybe it is something simple, but I'll have to find my compression tester(my garage is a nightmare - too many projects at once) and test the cylinders. I guess I should have done that before buying, but it was the friday before a long weekend and I was rushed because we were going away.
Sorry, not really an ignition issue. Thanks Cadman, I'll let you know how I make out.
