Does the crank and tranny look to be installed correctly? I just want to make sure the shift forks are installed correctly more than anything---is there any secrets I am missing?
I have a restoration log as well but didnt' know if anyone would look at it for this sort of help or not? What is the correct protocol for that---does a person post for help on the section of the bike you need help on or just ask for help when posting to the restoration log?
Thanks
Little expertise needed
Re: Little expertise neededRun it through the gears before you seal it up. I also dry test fit the bottom case half just for piece of mind. Makes it a lot easier if you have something not lined up you don't have sealer everywhere. Lastly, don't force it. I also recheck the shifting after it's together. 64' CB77
65' CB160
Re: Little expertise neededThe question was asked April 6.
You can bet it's together now. ......lm
