CL77 kickstarter arm problem
ggray
Post by ggray » Sun Jul 22, 2012 11:02 am
Hi guys,
Tried to start the Scrambler the other day and when I kicked down on the kickstarter arm it made a clicking sound on the way down and then stayed in the down position, (see attached photo)
Now I can't pull it up into the normal position.
I'm thinking a buggered pawl on the end of the kickstart shaft where it engages the main gear,
Any of you have an experience with this or Ideas? I haven't attempted to dig into it yet.
Thanks,
Gary in Joplin.
'65 CL77 Owner
Ford Guy
Post by Ford Guy » Sun Jul 22, 2012 11:20 am
You will have to pull the cover. THe spring could have broken but who knows untill you pull the cover. I might have an extra cover if you cannot locate what you need.
Jon
mike in idaho
Post by mike in idaho » Sun Jul 22, 2012 11:46 am
Could be the piece, in the cover, that engages the splined end of the kick start shaft. They sometimes will split. If the shaft itself is still in good shape it will be an easy fix.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
ggray
Kickstart arm
Post by ggray » Mon Jul 23, 2012 7:14 pm
I'll pull the cover and let you know what I find.'
Thanks,
Gary
'65 CL77 Owner
ggray
Kickstarter arm problem
Post by ggray » Thu Jul 26, 2012 6:51 pm
Mike, you nailed it. Pulled the cover and the kick start knuckle was cracked in two places.
Looking for a replacement now. CA's and CL's used the same knuckle 28241-259-000.
Thanks for the heads-up.
Gary
'65 CL77 Owner
StillNDADIRT
Post by StillNDADIRT » Sun Oct 02, 2016 3:35 pm
Where did you find this part for sale? I'm having trouble finding one
Post by G-Man » Sun Oct 02, 2016 3:51 pm
Pretty expensive if you can find one. They occasionally come up on eBay.
They can be repaired by welding. There is a high stress area where the slot ends. This is where the crack begins.
Drill a hole at the end of the crack to stop it going any further. Grind out the meterial near the crack & weld back up.
StillNDADIRT wrote:Where did you find this part for sale? I'm having trouble finding one
