Technique for removing "frozen" diffuser pipe
rone
Post by rone » Mon May 07, 2012 10:03 pm
It's called a diffuser pipe in the owner's manual, but I've also heard it referred to as the muffler insert. Anyway, on my 1965 CB77 both of them are seriously stuck in the muffler. I've removed the small bolt at the end of the muffler that secures the insert inside the muffler and I've even done some moderate "whacking" on the insert with a block of wood and small hammer, but I cannot get either one to budge. I want to get them out to either clean them up (probably the first time they've ever been serviced) or replace them. Does anyone have a suggestion for another technique for breaking these loose without damaging the muffler? And do they pull straight out, or do they require a turn to the left or right before pulling out? Thank you!
CliffC
Post by CliffC » Tue May 08, 2012 1:23 am
Rone, I would saturate them with PB Blaster and let them set for a while. If they are stock inserts, they should have a small bar running across the end. I have gotten them out in the past by using pliers that fit inside where you can get a grip on the bar. Slowly try to move it back and forth and in and out to break it loose. Don't use too much force and keep spraying to break up the rust/corrosion on the inserts. They will come out in time just take your time. Cliff
CliffC
Post by CliffC » Tue May 08, 2012 1:24 am
rone
Diffuser
Post by rone » Tue May 08, 2012 12:07 pm
Cliff: Thanks, I will give it a try. I've already tried with the pliers and these things aren't dudging a mm!
Phil-UK
Post by Phil-UK » Thu May 10, 2012 3:38 am
Hi Rone
If you cannot get them out as Cliff suggested ( I have had the bar break ) you could try the following technique which I've used to get corroded VW mutes out. These don't have the cross-bar or the locating screw and were just an intereference fit, and I wasn't bothered about re-using them.
I got a large thread cutting tap ( thread doesn't matter ) that was a tight fit into the end of the mute and tapped it in to start it. then turned it and that broke the stiction holding it still; by pulling on the tap as it and teh mute were rotated I was able to gradually remove the mute. The same method should work on a diffuser pipe but it probably won't be much use afterwards.
Hopefully you won't need to do this,
Phil
rone
thanks, Phil! Rone
Post by rone » Sun May 13, 2012 11:06 am
thanks, Phil. I've got them soaking in Kroil now and will keep trying to bust them loose. But I'll try your technique if all else fails.
