Lever Question
Lever QuestionSo I've got the lights working again, brake light works, horn works, I've added a centre stand, have put together most of an original tool kit and have started to do some tuneup/servicing on the 1968 CL77 I recently bought. I'm just curious about one thing. The clutch and brake levers do not match. Are they supposed to ? Here is a photo of the clutch lever which I am sure is original:
The brake lever has a round ball. is that correct ? I don't ever recall seeing a flat end brake lever, but than again I could be wrong. Comments appreciated ! My understanding is the flat end levers are intended to have black rubber tip covers over that end. The rubber covers are round.
That is what should be on my bike and I actually bought a NOS pair of covers from somebody here (short memory). I tried every possible way to install them and ended up tearing one, so I just threw the other on the bench and quit. Not something I do regularly. Anyone have a method to install those covers? Honda either had a special tool or the covers were molded over the levers at the factory. regards, Rob LeversWhen I got my 66 CL the levers were flat on the end and covered in a very thick layer of clear (yellowed) plastic about 3/4 the way up the lever. I,m thinkin a long hot soak in soapy water might get those rubber thingies on....................D
Old rubbersI have heard all the tricks too but have not talked to anybody that has had much luck with these. I have a good friend Vic whose been a Honda mechanic for 40 years, when I asked him about installing them back in the day, He tells me they had no real problems slipping them on with out tearing. His favorite method was to soak the rubber in water and slipping it over the ball while appling air preasure to the backside thru the small hole. Sounds crazy but Vic is the man on issues like this around here. I think the rubbers when new 45 years ago were fresh rubber and way more plyable than they are today. Thank God my resto is a 65 and I don't need a set.
Fast Fred 65 CL77
66 CL77 76 CB550FKR 76 CT90
No hole in the ones I had. I tried shooting air into the opening while fitting them. But with soap on them to help, they were hard to hold onto and all I did was launch them across the basement.
Inside out sounds like it might work. Of course turn them inside out will be a challenge in and of itself. I'll see if I can find that one I have and turn it inside out. The feature that might make this hard is the inside has a thick section where the flat on the ball end of the lever is. It's a hemisphere of rubber. Fast Fred, did I get mine from you? regards, Rob
