Do I need to find a replacement upper case?
cyclon36
Post by cyclon36 » Fri Apr 01, 2011 9:24 pm
I always wondered what that little mount was for. I have a CB77 block with one and one without one.
BTW, I have two spare engine cases if you should want one
zoom
Post by zoom » Sat Apr 02, 2011 6:38 am
Can someone measure the height of that thing and the height of the hole.
Thanks
ricksd
Post by ricksd » Sat Apr 02, 2011 5:57 pm
It's 25.5mm tall, 19mm to center of the tapped hole, and tapers to about 14mm diameter through the tapped hole.
Impurities make welding cast aluminum a little unpredictable, but a MUCH better option than epoxy putty and JB weld.
If you can machine a nice flat surface at the top of your broken boss, you could drill an tap a hole in both the case and a new boss- made from a chunck of aluminum, and use a long set screw as a sort of blind 'stud'.
I sent you a PM, I live fairly nearby and probably have a spare crankcase.
Rick
zoom
Post by zoom » Sat Apr 02, 2011 6:05 pm
Thanks, I'am making a new one. Thats what I needed, nice Pic. Hope it works or it'll be a new upper case. Another member has offered one up in case. Thanks everyone
Dr. Frankenstein
Post by Dr. Frankenstein » Sat Oct 15, 2011 8:00 am
Interesting...my 'early model ('62, I believe) has the same piece missing...I always wondered what that was for! Glad to know I can live without it!
