Rust out of the Gas Tank
Rust out of the Gas TankAnyone have any suggestions on how to remove light rust from the inside of the gas tank. Tried CLR but it had little effect. Thanks Gregg
I like to flush out tanks with something called Milkstone Remover and a handful on misc nuts and bolts. The Mikstone Remover comes from the local farm store and is actually Phosphoric Acid. I dilute it about 50/50 with water and let it sit a couple of days or more if needed and give it a shake every once in a while when I walk by. Drain it out along with all the hardware I stuck in there. The phosphoric acid leaves a nice coating that deters flash rust.
Tank internal rustThe more I read on this forum, the more I learn (well, that IS the idea, I guess!), so I'll try to impart some knowledge from the marine world myself: ferrous rust can be de-oxidised with Ferronet - at least, that's what it's called here in Europe - from chandleries or on the 'Net http://www.mercamania.es/a/listado_prod ... ductos.htm
or http://www.nautilus21.com/catalog/produ ... cts_id=448 where you'll need to understand a bit of written Spanish. See screenshot attached; the gist of it is: Liquid rust-remover Ferronet is professional quality and excellent yield (effect). Oxide eliminator: apply to the oxidized area. Leave it to activate for 5-10 minutes and wash away with water. (For railings, doorways, pieces, household-electrical ['white' goods] and all types of oxidized surfaces). Use brush, sponge, etc.. Calcium (limescale) decrustant: reduce to half, or up to 4 times, with water and apply. (Inside pipes, faucets, stainless sinks, etc.) Wash away afterwards with water. This stuff is good and simple to slosh around inside a tank. And I like the idea of a handful of nuts & bolts inside for abrasion/agitation - use stainless ones, also from chandleries (and cheap), as they can be reused without detriment. Steve
