CB77 completion
Post by G-Man » Fri Sep 24, 2010 6:39 am
Post by davomoto » Fri Sep 24, 2010 9:12 am
Rear torque arm located centerally in bracket, a collared bolt, and castellated nut secure it. There should be a bolt hole on the inner rear of swingarm for the rear chainguard mount. The speedo drive isn't installed properly, there are two tabs that must line up with the cutouts on the fixed bracket bolted to the front hub, or the wheel won't spin when you tighen the axle.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
masonmart
Post by masonmart » Fri Sep 24, 2010 11:25 am
davomoto wrote:Rear torque arm located centerally in bracket, a collared bolt, and castellated nut secure it. There should be a bolt hole on the inner rear of swingarm for the rear chainguard mount. The speedo drive isn't installed properly, there are two tabs that must line up with the cutouts on the fixed bracket bolted to the front hub, or the wheel won't spin when you tighen the axle.
Davomoto, thanks very much. I'd managed to fit it this afternoon but I didn't use the collared bolt so thanks. I'll check out the front wheel tomorrow. I have to go away for work again before finishing but I'm almost there now. The info and help that I've had from this site have been amazing and thank you all.
I'm really glad that it's in a position to be finished as I'd thought at times of just dropping it especially after it fell off the lift!!! I took on a bit much given the time, not done it systematically and then I had the 8 month break and forgot far too much.
