I have rebuilt and re-installed the carbs on my '67 CB77. Now I need some help with adjusting the needles. What should they be set to from fully closed?
TIA,
Scott
Carb. needle settingsI know on the CA77 single carb unit you should start with the air screw at 3/4 to 1 1/4 turns out from closed.Idle screw set until it just starts to touch /move the slide.There is a set up procedure for these here on this site somewhere in the FAQ's section I believe that is of more help for the CB's and CL's.
Carb. needle settingsJoe,
Found it in FAQ. Thanks for the tip! Scott
