250cc Pistons......
250cc Pistons......Hi All - I have a '61 dream 250 (ca72), and am wondering what pistons I can use...... Are the CB72 & CL72 pistons the same?
I have an opportunity to pick up a 3mm oversize set for a CB/CL 72 and am wondering if they will work ok....... Or, do I need to stick to pre-63 pistons (4 ring). Thanks!
Ok, well, despite a lack of info, I bought these pistons anyway.......
They're "Hap Jones" +3mm overbore pistons, and the box says they're for a CB72. Is there any reason I shouldn't use these in my CA72? Mines a '61 model....... I believe they will result in lower compression - is it worth skimming the head to restore this, or will I not have enough valve clearance to play with? Rob.
