Another issue... points cam orientation.
MBellRacing
Post by MBellRacing » Mon Jul 05, 2010 1:43 pm
Hey, thanks for the support!
After some sleep, I am significantly more upbeat about the situation. It sucks that it happened and pushes back when I'll actually be riding again, but its okay, and job #1 is to figure out what happened. I know I was quick to blame my head builder, but he is a very experienced technician, if a bit rusty on the SuperHawk. I'm sure something I assembled is the cause of this, or at very least, something that I just didn't foresee.
First off, the motor was reassembled with some NOS Kenig 10.5:1 race pistons. Since these are NOS and were last on a shelf in the 70's, I have no way of knowing what parts were sold with them-- like adjustable cam sprockets and the like. I am tossing the plan to use them. I just thought it would be an interesting touch to use them but are just one extra variable to worry about.
I really have no idea what happened first, but here are the pictures of the carnage:
The right-side piston, unscathed. Those swirls are not from some weird valve impact, they are from my rag that I wiped all the dirty gasoline off with.
The left-side piston.... not so lucky! It has the entire dome blown away clear to the rod pin. This is a big impact.
The valves on the left side are destroyed. I haven't gone all CSI: San Francisco yet to figure out how the valve was hit initially and if it damaged the head, but I'll let you all know. It looks like I might have gotten lucky and the exhaust might have just hit the intake valve without knocking into any aluminum. I'm not optimistic about that, though.
So here's my story, I'll include everything I've noticed about this engine in the last 2 days after reassembly with the cam / points cam issue.
I break in engines the race car way. 10-15 minutes of high idle, followed by slow sweeps to maybe 2000rpm. Once that's done, just a bit harder sweeps to the same or just higher rpm but never over that. After that's done, it needs some miles with load to set the rings. I had finished my first 10 minutes and had let it warm up to start giving it some harder sweeps from idle to low rpm. I had noticed there was some clean oil sitting on the cooling fins on the front of the motor right around the exhaust exit and again a little around the mating point of the head to the block the morning after the first time I started the engine. I had no idea how long that had been there. It worried me, so I cleaned it off before starting it the second time and was planning on watching it carefully to see if any of it forms again. I was fairly confident that I hadn't blocked any oil passages and also noted that there was, indeed, oil reaching the head, and escaping back to the sump. Upon starting it the second time, I saw that there were some wisps of oil smoke from the exhaust port before the retaining ring. I didn't think much of it because I had only quickly put these on to start the engine with the thoughts that letting exhaust valves feel the cool air directly on their rear faces is a very bad thing. I didn't put a super sufficient torque on the bolts yet but was confident that they were tight enough for their current purpose.
The engine idles fine, once again, at maybe 1000-1500rpm. I did a couple slow revs not much above that point and started increasing in amplitude from there, going off ear, as to not rev too high. As soon as it revved up a bit (probably not even to 2500rpm) it made and odd shudder. I did the same thing again, and the bike instantly seized. A small wisp of smoke poured from the inlet of the left side carb and I knew what had happened.
I tossed the frame off the thing and pulled the breather plate. The cam chain was dead tight on the tensioner side, and quite loose on the front, past the sprocket. The cam tensioner itself, once removed, was very free-spinning but it should be noted that I spent a lot of time making sure it was going to be that way. It was from a junk block pile at my neighbor's house since the block I was using needed the larger style that I didn't have. When it was all cleaned up, it was very hard to spin, so I spent a lot of time oiling and greasing and tugging on the edges to ensure it can freewheel. All the valve springs (which happen to be higher rate "racing springs") were intact. The right cylinder is very carboned up. I knew the bike would run a bit rich as I have larger jets than I think it will ultimately need. I went bigger on these due to different air filters and those high-compression pistons. Error rich better than lean, I figured.
Here are a few things I feel could have happened:
1) The chain somehow slipped. My neighbor said that the proper way to tension it is to install the tensioner, release the bolt holding the rod in so that it presses against the chain with no more than the spring's force, and re-tighten. The chain itself was the original one, but it seemed to be in very good condition. A motorcycle mechanic actually took a look at it next to a brand new one and said that he can't see any thing indicating need for its replacement.
2) The valve came unseated and impacted the piston. I don't know how this happens. Any insight would be appreciated. Could the smoke out of the exhaust be due to some compression leaking into the head somehow or oil leaking out into the cylinder? Again, I have no idea how this thing is assembled at the valves since I didn't do the assembly!
3) The piston hit the valve due to mis-timing. I am very sure I had the cam timing itself dead-on to spec. This doesn't mean it was correct for these pistons. I turned this motor over countless times and idled it for a total of 20 minutes before it collapsed upon itself. This leads me to believe that as long as the springs were doing what they're made to, there shouldn't ever be contact between the valves and piston, regardless of RPM, if not at idle.
Here is the motor idling on the stand the first time. This was 1 day before it popped.
http://www.youtube.com/watch?v=k8wwSL3A1aA
I have no tachometer, but didn't feel I was revving it high enough to cause any pre-break-in damage. I am very prudent with my fresh engines and try to take care of them properly. I've seen this kind of damage on race car engines that have been overreved or lose a valve, but never at 2000-3000rpm!
As I said, I need to pull this thing apart and really take a good look at what happened. I'll be going back to stock-style pistons but keeping the valve springs and valves. Since I'll need some new sleeves, I'll probably go back to the block (and tensioner) that this bike came to me running on just for continuity.
Any help is appreciated in solving this issue!!!
teazer
Post by teazer » Mon Jul 05, 2010 9:50 pm
What we do know:
The valve head did not break off
The valve hit the piston and bent the valve stem
What we don't know yet:
Why that valve contacted the piston
Speculation:
Valve may have pulled through collets. We need to see the top of that valve plus the springs and rocker arm.
The rocker arm could have broken and jammed the valve open. A photo would reveal that.
The cam chain may have broken or the split link fell off. Was the cam chain still connected after the destruction?
The cam chain tensioner idler wheel may have come apart and allowed timing to float (I am all too familiar with that one).
The tensioner may have been set at the wrong part of the cycle allowing the chain to whip when running.
The guide is probably damaged
Those are the most likely at this stage. As you pull the springs, valves and rockers out, let's see what you see please.
MBellRacing
Post by MBellRacing » Mon Jul 05, 2010 11:49 pm
I'll take some photos either later tonight or tomorrow morning.
As per your speculations:
The chain was intact and I had to cut it to get the head off. The tensioner side was VERY tight and the other side was very loose, but all the links were accounted for. The tensioner, once out, spins perfects easy, as it did when it went in, and the wheel looks unscathed. There may have been something wrong with the tension itself, as I said, I didn't get the best of instruction on how to tension it properly.
Does anybody have a good source for valve guides? I'm suspecting some previous damage as well as the bit that just happened.
teazer
Post by teazer » Tue Jul 06, 2010 12:07 am
I missed your earlier comments about the cam chain and tensioner. Thanks for clearing that up.
It's hard to tell over the exhaust noise but the motor has a few mechanical clacks that sound quite loud. Makes me wonder if the valve wasn't already kissing the piston on that side. As I said, it's hard to tell.
Let's see what we can see inside the head when you get a chance to take some pictures. BTW the exhaust valves typically run out of clearance before the intakes. How much was machined off the head/barrel and how much clearance was there between the valves and pistons when you assembled it?
thumper2146
yikes
Post by thumper2146 » Fri Jul 09, 2010 7:00 pm
OUCH!!!!!!!:(
James
thumper2146
why
Post by thumper2146 » Sat Jul 24, 2010 9:10 am
ever figure out why it did this??
james
MBellRacing
Post by MBellRacing » Sat Jul 24, 2010 7:05 pm
Not yet. I'm going to lay this on Charley's Place, a reputable classic Honda shop here in San Francisco. I'm going to leave it all alone until they take a look at it, preserve the crime scene!
I know this is all decent information and I apologize that I have been quite absent lately. I got sucked into my day job and got another offer to try this out:
You forgive me, right?! I think hopefully first of next week I'll head up there armed with parts and proof. I'll let everyone know what they say and what the avoidance would be!
