Here's what was said from Maggie at Dave Quinn Motorcycles:
In addition to:Hagons fork bottom shocks are supplied with 10mm/1.25 pitch bolt holes in
the fork; if your CB77 has 8mm bottom mounting bolts you will have to adapt
the swing arm to accept 10mm bolts.
It is likely that your CB77 has 12.5" top mounting studs; Hagons do not make
a bush this size. Most customers use Hagons 16mm top bush and turn up a
spacer, we can also supply Hagons 1/2" bushes which measure out to 12.7mm
ID, your choice.
