Post
by jensen » Tue Jun 09, 2009 3:53 pm
Hi Vince,
In theorie it's a simple conversion, practicly it was alittle more difficult.
The theorie / wishes / engineering considerations stated in 2003 where as follows :
1. All the oil should be filtered before entering the engine, no unfiltered oil entering the engine.
2. As less as possible machining on crank cases, it’s difficult and I can’t change it back in the original state.
3. Because the oil pump is rather a volume pump than a pressure pump the oil filter should have a low flow resistance and a large surface.
4. Changing the oil filter should be really easy, without opening the engine or removing importand parts.
5. Should be able to work with 10W50 full synthetic oil, and the oil filter should be easy to buy.
From a logical point of view there is only one place that meets the criteria above and that is a place before the oil pump, so I decided that the oil filter should be placed underneath the pump itself, as a part of the pumphousing.
Another advantage was that the the oil is drawn down by gravity to the lowest point (oilfilter) and thus the oil pump itself is not working different than in any other standard engine.
I bought several used oilpump housings to experiment, and finaly I machined a three part oil pump housing where the top (part in the engine) stays the same.
I removed the centrifugal oil filter, replaced the oilfilter shaft by a direct pipe with a diapragma to regulate the flow between crank, clutch and head and dismissed the oilfilter chain.
After years of optimising and further development (I destroyed / machined at least 12 oil pump housings) I got what I wanted, I even included a pressure sensor and a temperature sensor. On top of that the engine also gained an extra horsepower due to removing the oil filter and the chain (and less noise from the engine).
I hope that this answers the question,
