cam chain tensioner oil leakage
goudreignet
Post by goudreignet » Mon May 04, 2009 1:20 pm
After the rebuild of my CB77, I am breaking in the engine, the engine is oil tight except for the cam chain tensioner.
Oil is coming out of the back of the tensioner, along the tensioner shaft.
Is there a way to cure this?
Appreciate your thoughts on this
Fred.nl
Re: cam chain tensioner oil leakage
Post by LOUD MOUSE » Mon May 04, 2009 7:11 pm
What is your frame/emgone number?. .....lm
goudreignet wrote:After the rebuild of my CB77, I am breaking in the engine, the engine is oil tight except for the cam chain tensioner.
Fred.nl
goudreignet
Post by goudreignet » Tue May 05, 2009 10:19 am
frame nr. CB77F-1054164
motor nr. CB77E-1054231
it is a late model with the narrow tensioner
fred.nl
Post by LOUD MOUSE » Tue May 05, 2009 12:21 pm
THANK YOU. INSIDE YOU WILL FIND A "O" RING THAT SEALS THE SHAFT. ...............lm
goudreignet wrote:frame nr. CB77F-1054164
fred.nl
FAST FRED
O-RING DIMENTION
Post by FAST FRED » Tue May 05, 2009 1:45 pm
FRED, THE O-RING PART NUMBER FROM HONDA IS 91306-259-000 IT'S 7.4X2.4MM. ITS NO LONGER AVAILABLE IN THE US. THE CLOSEST O-RING STILL AVAILABLE IS 91307-PM7-003 IT'S 7.3X2.2MM. I DON'T THINK THATS CLOSE ENOUGH TO WORK. I'LL PUT THE CORRECT O-RING ON A HONDA CRITICAL SEARCH AND SEE WHAT COMES UP.
FAST FRED
65 CL77
66 CL77
76 CB550FKR
76 CT90
goudreignet
Post by goudreignet » Wed May 06, 2009 3:03 am
thanks LM, an o ring, i was on that route but could not find one in the parts manual
speaking of that, i could not cross reverance the part number you provided Fred in the parts manual from mr silver
but with the information from you guys i will get an oil tight CB77 as it should
Fred the p/n you privided is aviable at cmsnl and i have ordered one
thanks for youre offer / surch to get me one
LM and FF youre help is much apriciated and put in to good use
thanks
fred.nl
