sd
bigscooter
Post by bigscooter » Sun May 03, 2009 8:40 pm
hi, and welcome . that's definitely a ca160. they are great bikes! the 160 is more uncommon than the 150, and a much better engine. it has 4 main bearings when the 150 only has 3. the vin# is
under the left side cover, almost back by the tire. you should spray some wd-40 or pb blaster in the spark plug holes to help loosen the rings, and soften any oxidation that might be on the cylinder walls. do you have the chrome tank covers?
bigscooter
Post by bigscooter » Sun May 03, 2009 8:59 pm
here is where you can find a parts breakdown for almost any honda.
http://www.cmsnl.com/honda-ca160_model118/
just type the part number in a google search, and you will find any obsolete parts suppliers.
